1 - 12 of 12 Posts
Text for fastest response and pics... 440-476-41114
I have parted some engines lately have lots of parts here....
I have a set of 8- MMR .020 dish pistons here and look to be Scat forged H beam rods, no issues at all cams from a running engine
750.00 plus ship
I have a set of 8- Manly H beams "SVT" rods and sock 03-04 Cobra pistons, one piston has a ring land smoked (set of 7) basically and one rod has a bolt issue, both can be fixed, 425.00 plus ship
I have a virgin std bore no issues, no spin bearings was taken apart thinking there was a spin bearing, all is good.
300.00 picked up 44138 Ohio
I have 2 Teksid blocks .020over ran when taken apart, 325.00 each plus ship
99-04 C heads with Ford GT supercar cams no issues 1000.00 plus ship
Another set of 03 Cobra heads 550.00 plus ship
Set of 99-04 heads one got beat up from dropping bolt in, can be fixed 300.00 plus ship
MMR billet oil pump and pick up NO ISSUES 200.00 plus ship
ARP Main studs and side bolt kit 200.00 plus ship
99 C head Lower intake with adaptor to 96-98 B head upper, 500.00 plus ship
96-98 Complete Vortech T trim!! uopgraded blow off valve, and piping.... 2700.00 plus ship
Stock oil pans 50.00 each
all smaller items plus ship....listing whatever comes to mind, or ask me... I have a barnfull of chit!!!
03 Cobra oil cooler 200.00
96-98 oil coolers 125.00
96-98 Timing covers 80.00
heater hoses 40.0 each
T stat housing and hoses 03 cobra 100.00
T stat housing and hoses 80.00
stock exhaust manifolds 100.00
starters 30.00
96-98 Alternators 50.00
99-01 50.00
tensioners 30.00 each
96-98 coolan crossover 80.00
ASK .... ask .....ask.... I have tons just ask....
also body, suspensions, drivetrains, rear end, interior parts all 94-04 Cobras!!! text 440-476-4114
Do you have any 4v shortblocks ready to go? Looking either stock 03 Cobra or built with aluminum block and around 9.5 and up compression.
If you don’t keep me in mind if you run across any please.
Ken
1 - 12 of 12 Posts
