1 - 9 of 9 Posts
what is the diffrence between a blow thru maf and others. im on jegs looking at diffrent maf's and i dont see any that are blow thru ones
yes.. but there is a bit of a learning curve... depending on your mods you might be outflowing the stock maf already..
I have no mods done to the motor its just a stock 5.0. What if I used a ford lightning maf would that work because there a little more cheaper?
first, you'd have to cut cut off the stock pigtail and put in the Lmaf as they are different.. though there is someone out there that makes a jumper harness...
one benefit is that if you decide to jump into the world of tuning, this seems like a good way to start... little steps and you get comfortable with the software.etc..
1 - 9 of 9 Posts
