1 - 20 of 21 Posts
Short Story: Got half-way through a new build and then ended up relocating. Project sat for a few years and I just got it to fire up. Although it fired, it was running unbelievably rich in the 9:1 range. I started to go over the wiring by ohming out wire runs all the way back to the ECU harness connector. I discovered that the MAF connector was wired backwards by me many moons ago.
Assuming that the correct wiring is as follows:
A=PWR-37
B=GND-40 or 60
C=Signal RTN-9
D=SIGNAL-50
Mine was wired as follows:
A=SIGNAL-50
B=Signal RTN-9
C=GND-40 or 60
D=PWR-37
Can I just correct this and be on my way or did I cause some other unforeseen damage?
test it by taking a voltage reading at idle
back probe the pins
0.7-0.9volts is a usual signal voltage
battery voltage to power
less than 125mV on the grounds
Thanks, that is helpful.
I am optimistic that I can get it to idle now, so I should be able to back probe.
Any chance that my wiring screw up could have ruined the meter or the EEC? Would this error have caused the absurd rich condition?
anything is possible, but its unlikely in your case, unless there is something you are not saying
the eec will ignore the maf, if its signal is out of range
yours would def be out of range
if your ecm is programmed for the actual injector you are using
limp mode should have correct fueling
if your ecm is NOT, limp mode may not work correctly
the above test will verify maf integrity
this is just another reason, for correct tuning
and not using a 'calibrated' maf
fords dont use them
I hear ya on the correct tuning and agree with that. This car does have a chip in it, but I have no idea what is actually tuned on the chip. So with the car having 30lb injectors, a screwed up C&L MAF, and a possible ECM not tuned for the injectors it would result in a pretty rich/rough running car.
Just because there is a "tune" doesn't mean the ECM was corrected for the injectors, correct? A "tune" can still rely on the calibrated MAF signal for the injector compensation if the tuner is lazy I suppose.
Next time I start the car I will do so on the A9L alone, 30lb injectors, and calibrated C&L MAF as I should be able to get it to run under those conditions.
if the chip is done correctly, limp mode should be correct
when you say running rich, i hope you are using lambse from a log
if it is from smell, or plug examination, that is not reliable
was the 02 voltage at?
not sure as I have not probed it yet. With as little run time as this car has had, I am assuming that the wideband is accurate. However, a voltage check as you suggested will support that assumption.
I am making a list of things to check if the cars gets running as I need it to run well enough for me to exit the driver's seat.
MAF voltage first
Fuel pressure adjustment second if needed
Timing adjustment third, should be pretty close to 10 now, but will need more if the MAF fixed the previous issue. Timing adjustments with the screwed up MAF wiring really had no impact in the 0-20 BTDC adjustment range.
Narrow Band O2 sensor fourth
Wide Band O2 sensor fifth
I picked up some T-pins from a craft store yesterday so I can back probe the aforementioned items later today if the car will run on its own.
Thanks for the feedback thus far!
i recommend piercing adapters as well, T-pins sometimes are tough to use
fuel pressure adjustments will throw off fueling
set it to injector spec once, and never again
in fact i recommend non adjustable reg
I would not trust WB readings, too many variables
until you can verify they are following NB and lambse
tuning fuel is the first thing you do with a tuner when the engine is nice and hot
Discussion Starter #12
just to double check, are you saying that I should see 0.7-0.9 volts at idle when I connect the red meter lead to the wire D (MAF Signal) and the black meter lead to the wire C (MAF Signal Return)?.
This voltage should then increase with throttle application
one lead at battery negative
probe each wire, while running with the other lead
that way you check all current carrying conductors
Discussion Starter #14
Thanks.
I got the MAF rewired today and will start it up sometime this week to check everything and post results.
Discussion Starter #16
Just to update this thread, I ended up correct my wiring mistake and I went ahead and put a Pro-M Maf for the 30lb injectors.
Car will start up and I can get the rpms to hold steady around 1000rpm with my foot barely on the throttle and A/F looks good. I have not been able to get it to idle on its own just yet, but it seems I am moving in the right direction.
cold start a/f is what?
Discussion Starter #18
It was a little rich in the 13.5-13.9 range.
I didn't run it too long as I noticed an oil leak at the back of the manifold, so I still got some tinkering to do to fix that leak and play around with the timing.
Will I ever be able to get it to idle without throttle on the stock ECM with the 4R70W behind it? First time with a combo like this and I was assuming that I would need a slightly higher idle to compensate for the drag of converter/trans. Is this true or did I just make this up?
cold start requires more fuel and air
without seeing what is being commanded you will never know if it is rich or lean
but, that a/f is pretty good for cold start
your idle issue is not from the trans, its has do with you fooling the eec with a skewed maf and probably an incorrect throttle blade position
if your maf is reading less air than is really entering, that is what a skewed maf does,
do you expect load to be higher or lower than it should be at idle?
Discussion Starter #20
I would expect the load to be higher at idle due to the drag of the converter/auto combo.
Is that an incorrect assumption?
As far as the throttle blade position can I offset it by simply re-aligning the IAC position sensor? I did open it up some as I was trying to get the RPMS up, but quickly realized that was a bonehead mistake. I got it set back to original position now as I was smart enough to take a starting picture of the set screw. I was hoping that I could open up the throttle body a tad and then readjust the position sensor to get the rpms up.
1 - 20 of 21 Posts
