1 - 8 of 8 Posts
Im running a on3 turbo kit and have a question regarding which maf to run. Can i run my 90mm cobra mass air or is it required to switch to a blow thru? Thanks
I used a weld in bung for a slot style MAF.
Works fine, less silicon cupplers on the charge side is a good thing.
Good luck!
I'm also a fan of slot style mafs with welded mounting pads. Very easy to add on your existing cold piping and it'll be post-BOV so no issues with losing metered air.
I’m currently using a Pro M 3” blow through tube in the drivers fender well. Works good. I had to cut a section out of the pipe coming from the intercooler so it would fit.
Hpx-e, so you won't peg it.
Sent from my Pixel using Tapatalk
1 - 8 of 8 Posts
