I am looking into swapping an L33 5.3 liter LS engine into my SN95 Mustang. I really like the shift quality of my old Ford T5, and would like to retain it if possible. I've heard of people keeping their t5 transmissions in their 80s f-bodies when doing LSX swaps, so I don't think this is impossible. I would probably rebuild the t5 to z-spec. Could I use a 1980s f-body bellhousing to make the swap work? I was planning on using a UPR k-member to bolt in the LS engine. I don't plan on drag racing this car. Thanks.
Discussion Starter #2
Found this on ls1tech.com
I found this on ls1tech.com, the following components were listed as making this swap possible:
Quicktime bellhousing RM-6037
Ford throw out bearing
gm pilot bearing with ford inner diameter
ls1 flywheel
ls1 pressure plate
11" ford 10 spline clutch disk from 2000-up gt mustang
LS1 to t5 questions...I searched - LS1TECH
My problem is that the quicktime bellhousing cost over $600 bucks, and I would rather just use an old 80s F-body one. If anyone knows the answer, your help would be greatly appreciated.
where can you buy this:
The GM T5's don't use the Ford bolt pattern on the face of the transmission.
The Ford and GM input shafts are also of different lengths.
Exception: GM started using the Ford bolt pattern for most T5 applications in 93. Unfortunately, none of those are V-8 rated transmissions and the input is still different.
GM T5's only appear in 4 and 6-cyl models after 1992. (F-body and S-10)
