I have a 1998 mustang that I'm using as the platform for the swap. This mustang uses a returnless fuel system (like the 99-04). Is it possible to convert my mustang to a return style system on the cheap?
If not, I found a 1997 tank for $100 buck that I'm going to match up with a walboro pump and corvetter fuel pressure regulator.
Any advice would be greatly appreciated. Thanks in advance.
you can just add a return line to the tank...
Drill a hole, add a fitting(preferably welded on)
or you can add a sump pan to the tank, and use the hat as the return with a simple fitting that snaps right onto it
