1 - 20 of 35 Posts
Ok so im starting my build...
I have so far
complete 6.0 intake to oil pan
4l60e built with 3000 stall
computer
wiring harness
Im going to buy the AJE lsx swap k member and going to try and use the stock exhaust manifold for now unless someone has tryed it and it didnt work..
going to make my own trans cross member and going to use the zo6 vette fuel filter with built in reg for a return... going fuel injection is there anything else im going to need...
any place you guys are getting the AJE K member for less then 400 with spring perchs motor mounts and hardware??
Go to ls1tech.com and the Conversions and Hybrid thread......there is a ton of info on there about the swap. I started my build thread not too long ago. Good luck on the build.
Just an FYI your truck oil pan will not work with the AJE kmember youll need an fbody or cts-v oil pan. Do some searching you'll find a decent amount more stuff youll need.
I already have a 6.0 but i just picked up a 4.8 with drive by wire, drive by wire pedal, wiring harness, fuse box, computer.... complete from oil pan to intake with coil packs EVERYTHING for 400 bucks!
My truck pan works fine, it's too low to the ground for me though.
Thats what I meant, most wind up cutting and welding for more ground clearance.
6.0 > 5.3 > 4.8.
I agree... but 400 for dirve by wire pedal wiring harness computer fuse box and all sensors are worth 400 bucks... its like the 4.8 is free and can be used as mock up for the 6.0! make everything work on the 4.8 and once i blow it up if it brakes i swap out for 6.0... plus i get to see what a long tube header and cammed 4.8 will do in a mustang
would be a good motor to see how much nitrous one can handle before it blows
here is were it's at..
And it's getting one of these
Discussion Starter #12
started fabbing single 76mm turbo kit
welded v bands on to Stock 2010 camaro exhaust manifolds
cool, looks good
That's a damn nice looking hot side you put together I like the car alot
Discussion Starter #16
thank you..
got a little further on the build, all the wiring is about done... car now has a f body oil pan on it.. still need to do cold side and install wastegate.. install a inline 255 lph pump ( if anyone has one for sale let me know..) and connect fuel lines to rails... found out Drive by wire throttle bodies don't like boost, they have problems over 12 lbs pushing throttle body open making PCM go in to a limp mode.. so now have to convert harness to cable throttle body... its coming together. hopefully the end of this year she will be ready to make some noise!!!!!
Discussion Starter #17
Forgot about this thread car is ALOT closer got injectors in it new gm 5 layer head gaskets for it along with a set of arp head studs. Cold side is done and it's been converted to cable throttle body just need to install my turbonetics 44mm gate put fluids in it any my meet my end of year goal of making it run..
Not happy with starter and alternator wiring so it will be redone, it the red box next to alternator
Is that an actual kit or is it something you're piecing together?
Discussion Starter #19
100 percent custom kit. Only thing in this swap that was bolt on was the aje bad ass k member
Did that K member work out good for you? Looks like a lot of people on here use them. I'm planning a 6.0 swap myself, but not sure if I wanna go through the hastle of boosting or not. I'd really like to but don't wanna go through all of the custom fab stuff for the turbo kit.
1 - 20 of 35 Posts
