Looking for part numbers on the correct bearings for rods, and mains. Also what piston rings should i be getting. All oem spec. Pease. 364ci at 4.000" bore
Info
I just had a learning experience on the LQ4. If you have a 2004 and newer the cam bearings are different. I ordered my rings Mahle brand from Rockauto. But mine is a stock rering with a cam.
Its a 03 but thanks on the piston rings. Now to find out what bearings i need.
Thanks for the info. Any idea on what hone brush I need. Like grit and material and all.
What material hone brush?
