having a problem with starting i have 408 windsor, starter is sluggish
xs torque master starter brand new
grounded to frame very well and motor
red top battery optimum 800 cca new
1 out cable to trunk batt location
using factory starter solenoid switch on fire wall
i can not figure out why this thing want turn over freely
had this trouble for years cant figure it out any solutions
why is there something i can change upgrade the batt to marine batt
get a high grade starter switch some one said im losing volatge to
the starter what causes that i have alot of electronics alot on relays
but still it does not consistently turn over well to depend on need help
please
re write your post, so one can understand it.
Yeah, what the other guy said. Have you checked the voltage difference between where the cable connects to the solenoid and where it coneects to the starter- while cranking? You might have to much resistance in the starter cable. I'm not an electrician but that would be a simple way to check the difference and give you an idea of what you have.
I agree with Black88coupe, if you have been having a problem for a while and you changed the starter, solenoid and battery then the problem lies in your cables or relay.
