hi all..i'm looking to build a nice street/strip 1995 mustang
have a freshened 302 with trick flow 170 as cast heads, F cam,and edelbrock II intake
turbo is a single 64mm on a older kit with a front mount intercooler
six speed trans with 3.55 gears in the rear with a CF track loc
42lb injectors,pro-m draw thru, 340 intank,stock rails with adj reg
msd 6al ,stock dizzy and stock ecu
looking to make around 450-500 at the wheels pump gas...anyone build something similar in a 94-95? thanks in advance!
do you thnk I could do it with a stock cam? I don't have a way of tuning it as of right now
and even tho the F cam isn't really radical..i'm not sure how its going to idle and run with the stock ecu
I can't say from personal experience but I've heard of a lot of people having good luck with stock cam. Either way stock cam or not your will split the block before you reach its max potential.
As far as tuning you need to find a good tuner either way. Unless you want to try and tune yourself
