Well I ditched the on3 turbo and bought a turbonetics ball bearing unit, where is the best place to get coolant from to run to and from the turbo. This is on a fox.
I'm in the same boat as you. I'll be running water cooled Turbos as well. According to the Garrett paper, hot water rises. So that water movement will push it's way thru the Turbo.
