Can the line lock go before the distribution block? 85', 2 lines into the block from master cyl., 1 for the front brakes that splits when it comes out of the block and the other for the rear brakes. Will it work if its put between the master cyl and the distribution block for the front brakes? Thanks
It will work that way but if you are into being NHRA legal it needs to go after the proportioning block. That's taking into account they'd actually look during a tech in.
