1 - 16 of 16 Posts
looking for a cheap set of 17x9 or 17x10 wheels for sn95. any suggestions? i have 13" brembos on front i want to run 275/40/17
. i have 03 cobra 17x9 x 17 x10.5 now. looking to run square setup with lighter wheel. thought about enkei rpf1 not sure if they will fit. anything else that is similar in weight and price.
Jay
Jay
I'm using the RPF1 in a 17x9.5 with 275/40-17 and they are great. 16 lbs each and tons of clearance for my Cobra R brakes. I swear I can feel the difference in acceleration going from a 25 lb wheel to these and the suspension feels better too.
what offset are you using is your car a sn95 thats where i was confused if it would work with no spacers
I have no idea what the offset is. The guys at Discount Tire ordered them for me. In my sig you see that the car is a 2003 mach1.
On the Tire Rack website the 17x9.5 RPF1 for a 2003 Cobra shows a 18mm offset.
I can tell you that I've got about 1/2" of clearance between the spoke and the caliper.
Thanks I found some 17x9.5" 18mm offset on craiglist and they fit on my 95gt with 00r 13" brembos very good. They have the sbc coating. Thanks for your help!
I think you will find them to be a great upgrade.
Discussion Starter #14
i think they will make a huge change. i weighed the difference. 11lbs lighter per wheel on front. rear i was running 17x10.5 with a 315 going to 275 40 17 and that rpf1 -20lbs per wheel!!
I tried to reply to your pm but it wouldn't work but yes I go to CMP often. Next time will be 2/24.
Running RPF1 17x10 with a 275 tire on it. Fits pretty good, super light, pretty affordable. I do hear their are soft though. Having said that, mine have been fine so far.
1 - 16 of 16 Posts
