Checked the fuses.....all OK
The accessories on the same fuse circuit work.
I think the headlamp switch may have dirt/ bad connection.
I understand there is a clip to remove the knob, before the switch can be removed.
I wanted to try contact cleaner before replacing the switch. Any ideas?
I would try the switch, they all eventually go bad on our cars. You said the fuse was ok and all other accesories work on that same fuse circuit? Unless ALL of your bulbs burnt out *insert sarcasm here _____ * then it's safe to say that you need a new switch. I would also check to make sure you have the right size fuse in ALL of your locations.
