Is it possible to use a lightning maf on my tubo project. And if so I guess it would work as a draw thru instead of a blow thru correct?
It can be used in either configuration draw or blow through, keep in mind when configuring in a blowthrough setup it will lose range and depending power level and injector used this could result in pegging the meter, some will add a mafia however we prefer a slot style MAF and not have to worry with range or a voltage aid.
Thanks,
PAS,Inc.
