1 - 20 of 28 Posts
im bored... so lets play a game. i have a pretty good idea what its going to run but lets see what you guys think
408" windsor
1050 QFX
2828 glidden
225 highports by BES
cam will be a solid roller from bullet.. sam vincent... ed curtis... (no idea yet)
nitrous outlet stinger plate with roughly a 300 shot in it (kinda depends how much it makes on motor)
13:1 compression
2.20 first gear C4
converter will be a billet deal from Pats
UPR front and rear suspension
afco rear shocks
mini tubed
car "street" car...
should be roughtly 2800lbs with me in it
c23
275 radial
I'm going to stick with my guesses. We have a class around here limited to stock block. Sam Vincent done a racers combo and has proven you can go low low 5s at like 3100lb with a stock block and single plate.
im leaning his way for doing the cam... nothing against Ed at all! but when you talk SBF nitrous combos the name that stands out is Sam Vincent!
1/8*1.56 is what ive always used for 1/8 to 1/4...
9.30 on the motor
Discussion Starter #14
How close are you to being done.
Interested in the results for sure
goal is to have the chassis done and wired up this year... motor next year. i still need a crank and have roche order the pistons. then the short block is done. heads and valve train are done other than cam and push rods. still need intake carb and nitrous plate.
Discussion Starter #16
LOL my money is short and my time is shorter. between house work... family ####... work... the X275 car... free time isnt something i have a ton of
Discussion Starter #17
and for those guessing low 9's on motor with the nitrous converter...
if you guys are right i'll be happier than a pig in ####!
i honestly think its going to go somewhere in the 8.50 range
Mid to bottom 8's in the 1/4 mile or you are doing it wrong.
or the blocks coming apart
Well I suppose if you detonate the crap out of it, then yup. But you probably know more about a Nitrous tune up than most of us here, so that should not be an issue.
1 - 20 of 28 Posts
