Are you able to swap the manifolds between a 1.5 and a 2.1 on the 94/95 (I guess the foxes as well) kits? I know there is the extra bolt hole that would either have to be drilled or filled in, but do the rest of the bolts line up? Thanks in advance.
You have to take in consideration that some Kenne Bell intake manifolds were for a stock lower intake, and some were for the Cobra/GT40 style lower. Beyond that, not sure if the holes on the blower itself are the same.
