JBA Long Tube Headers
2005 Mustang GT
The new Ford Mustang is the most anticipated vehicle of 2005. All of the articles, car shows, and sneak peaks have put the new car in high demand. With 300hp on tap and an improved suspension to help get the power to the ground, the new Mustang is a runner! Given JBA's roots and long standing history as a leader in Mustang performance - we had our sights set on developing performance exhaust products for America's favorite new hot rod long before it hit dealer show rooms. At the 2004 SEMA show in Las Vegas JBA unveiled the first complete exhaust packages for the ‘05 Mustang including new long tube headers, smog legal Cat4ward® headers, H-pipes and after-cat exhaust systems. With these precision made components you will see gains of 23.4 HP / 28.3 lb.ft. at the tires.
JBA dominated the 2004 SEMA show with the industry's first long tube header and exhaust package for the ‘05 Mustang GT. Crowds of Mustang enthusiasts filled the JBA exhibit to see these exciting new products. These new headers take full advantage of the redesigned chassis and new engine. The trick "D" port aluminum heads on the 4.6L 3v can breathe easier through JBA's 1.625" mandrel-bent stainless steel primaries freeing up massive amounts of horsepower and torque. JBA's one-piece .375" CNC laser-cut flanges make a tight and durable seal for trouble-free performance. The pipes terminate in a 9" long collector that houses JBA's patented Firecone® merge device for enhanced scavenging of exhaust gasses. These headers fit perfectly inside the frame with no loss in ground clearance.
::Header Benefits::
• Increase hp & torque throughout RPM range• Improved throttle response• Quicker rev• Amazing sound• Reduced under hood temperature• Improved exhaust scavenging
* results may vary
::Header Features::
• 3/8" thick laser-cut flanges• Mandrel-bent 409 stainless steel primary tubes• Patented JBA Firecone® merge collector• JBA Slip-fit™ collector• Premium quality hardware and gaskets• Bolt-on installation• Optional ceramic coating (thermal barrier)
Blow-By Racing
131 NW 13th Street
Suite 39
Boca Raton, Florida 33432
561-417-5555
www.BlowByRacing.com
Bet those are fun to install!!
On the 05 Mustang there is plenty of room between the k-member and the heads. Install isn't that bad.
Just curious. So how is the install? Is it easier to drop the K or can they be put on with everything in place?
Install is not thant bad, you may have to dis connect the steering shaft and lift the motor slightly. other than that not bad; compared to 99-04 header install.
how much?
$599.99 is the price on the Longtubes.
