1 - 16 of 16 Posts
not a chance in hell
Another one for the burnout pile!!
How did you even gouge it like that? Inner fenderwell a bit close?
Its a friend's car he asked, i told him it was junk. Id thought id see what u guys had to say. He already ordered a replacement. Appearetly the bigger shot off the trans brake gave the car the squats.
:bs: but glad you got the new tires on the way >:)
Any idea what kind of 60' times he got on those?
BTW - I wouldn't risk my life on those either.
then his suspension is wrong LOL
Discussion Starter #15
ouch man, I hope the problem will be fixed before it happens again, that being a 26” tire, is it too low a rear spring or too soft?
He actually just put set of coil overs on the rear with a stiffer spring rate. Also found a broken weld on the rear sway bar to diff housing mount. Between the 2 of those the car has no more problems and he switched to a MT radial pro
stiffer spring is just going to band-aid the issue... with a radial you want to stick the tire and keep it planted.
if the car squats when he lets go of the button hes just fighting a loosing battle
1 - 16 of 16 Posts
