1 - 11 of 11 Posts
I had a guy tell me that I was going to burn up my turbo becaue my drain line was too long. Can you guys take a look at this and see if thats true or if this guy is talking out of his a**. He also said that little pieces of the filter I am running will get sucked into the turbo. I am using the same filter that I have seen 90% of the cars here run. Thanks guys.
That line could use to be a bit shorter. just enough to get it as short and as direct as possible.
what kind of filter?? K&N is the best and sometimes even they will collapse or rip. Most guys just run a screen, its easier on the turbo.
lol I wondered that myself... "they" say it doesnt have to work as hard if it dosent have to pull through a restriction. Im on my 2nd K&N and its sshowing signs its about to collapse again lol
I have read over on Yellowbullet that Screens are more restrictive than you would think.
how is sucking in dust and dirt and lord knows what else better for a turbo?
Because if it's too small it causes a vacuum in front of the impeller which causes an axial load which can wipe out the thrust bearing.
Too long won't really be a problem. But because your is too long, it not draining straight down in the most direct path. If it's not smoking, you'll be fine.
i dont see a huge problem with it. but as easy as it is to fix it i would make it shorter. dont want to wipe out your turbo for something so easy to fix.
Thanks guys, I am going to go ahead and shorten it a little bit just to be on the safe side.
maybe that why i spent all that time moving the biggest 4" inlet filter i could to chads kits :rolleyes:
if that thing is a restriction, theres a big issue.
and if the turbo was to suck that screen in, your not going to be worried about the thrust bearing.
We weren't talking about your kit now were we ? The subject was IF the filter was too small.:shakehead The same problem can occur when running a turbo inlet reducer when running in class races. Screens are restrictive as hell also, I wouldn't run unless it was only to keep large particles out at the track
1 - 11 of 11 Posts
