1 - 13 of 13 Posts
no one uses header gaskets on their turbo kits?? I was ready to go out and get some soft aluminum header gaskets that crush and seal but looks like all anyone uses is copper rtv between the header and head....
I can see using it but you mean with no gaskets, rtv only correct?
That is how I do mine is copper rtv only no gasket
tried to use copper gaskets and failed miserably, causing fitment and terrible leaking issues. removed gaskets and used copper rtv with no gasket and no more trouble
Do you guys spread it on the thin side or more thick??
real thin, almost to where you can see through it.
1 - 13 of 13 Posts
