1 - 13 of 13 Posts
I'm doing my own Turbo kit and do not want more than 400-410 rwhp.
The Turbo used is 62 mm.
The intercooler I found here has a core size of 8.3" ( height) x 25" ( width ) x 1.9" ( thickness ). The reason why I am thinking of this is because importing an intercooler will cost me a lot.
Will it flow sufficiently or will it hinder performance? I will also be using this with a methanol injection kit for more cooling.
Here are some pics:
that will be a restriction and i would not try using it. You need it to be at least 2.5" thick at the minimum but recommended that it be 3" thick. Also needs to have 2.5-3" inlet and outlet. you can have a local shop build you an intercooler
I think I'd probably forget the ic and see how much hp you can make with just the methanol injection.
+1. When i ran a vortech i made 461rwhp @ 11psi with meth and no IC. Was my daily driver back then
You could a cheap cxracing intercooler and be fine up....
I'm quite sure you could get 400 rwhp with that cooler... BUT - why build a turbo motor for only 400 rwhp? That's like dating a supermodel and putting a bag over her head when you sex her.
Instead of starting a new thread I'll post this here...
I've got a cx bar and blate 31x12x3 3"in/out. Will this intercooler work for 600rwhp? I'm also running alky inj.
I've ordered something similar to yours and I'm sure it supports 500 rwhp, no idea regarding 600 though.
Can you translate? HxLxW...The end tanks look the same as what the cx racing bar and plate kit but are shipped from cali and I can read the description:p
1 - 13 of 13 Posts
