How do you set up system to check temps. What sensor or do you build one etc...... Best place to put it? I want to set one up but I am not sure on what sensor to get or build for that matter
Is this a serious post?
I use a Holley Dominator EFI ECU to monitor air temp sensors (ambient, pre intercooler, post intercooler and in the intake elbow behind the throttle body). My sensors are simple 2 wire GM units scaled by voltage in the ecu.
Yes it's a serious post. I don't run a fancy aftermarket ecu so I'm not sure how to go about setting a system to read iat. Why would you even respond if you found my post stupid. Thanks for being a valuable contributing member to the corral community.
