1 - 8 of 8 Posts
I have a '96 GT with an automatic, I'm going to have 4.10 gears put in it. Is a new speedo gear all I will need to make the transmission shift correctly or will that just make my speedometer correct?
Speedo gear has nothing to do with your shift points. It will only help your speedo. Your speedo will still be way off. You will need a Speedcal to correct it completely. Your shift points will be WAY off. It will shift very, very early. You will need a chip to correct your shift points.
pthornton said:
I know the shift points are in tables in the EEC, but how does the computer get input from the transmission? The computer has to have a connection to the transmission. Is it the VSS or it is a different sensor(s).
96 to 98 autos had separate sensors for the speedo and the shift program. The speedo uses the VSS, same as the 5 speed. The shift program uses the OSS. In 99 Ford combined the VSS and OSS into one sensor and kept the OSS name. So on a 96 to 98 auto you can correct the speedo with a different driven gear or an electronic adapter, but not a chip. You still have to use a chip for the shift program. On 99 and newer you should use a chip to compensate the shift program and the speedo.
Ok with all this said will a SpeedCal from DallasMustang be all I need to fix this or will I need it and a chip.
Sorry, but to fix the shift points you will need a chip and for the speedo you will need a different driven gear or electronic adapter.
1 - 8 of 8 Posts
