1 - 14 of 14 Posts
Alright looking to up my injector size to 120lb ones. Using the stock harness and aftermarket rails (proly aeromotive) tuning with moates...What brand and do I need High impedence?, or do they even make high impedence with this size.....Just needing to find out what I need to buy.....Thank for the help....
I wouldn't do 120 lb injectors. I had all kinds of problems. Save up and buy a set of id1000's. I might be selling mine to get the bigger ones. Pm me if u are interested. There is no data for 120 lb injectors. I found out the hard way.
How much do you want for the id 1000 injectors?...Whats your reason for selling?...
If you're making enough power to need 120 lb/hr injectors it's about time to step up to a stand alone ECU.
Formerly eades5.0
I love my 120s from FIC. Their customer service is bar none, and when I called ID alls they wanted to do was talk crap about FIC (tells me alot about a company). I couldnt deal with ID's price either.
My car idles and drives perfect, but I also do not have a stock cpu.
my car idles and drive's perfect on 120's as well..on a stock ECU with a Kurgan tuned SCT chip...
We also carry the TFS 120"s that are low impedance, we have a sale on the TFX injectors currently.
ID and FIC make great injectors, depending on your budget I prefer custom flowed injectors for tuning reasons/data but I will say the TFX 120"s do good with proper calibration.
We offer these as well.
Fuel Injector Clinic
Yeah I was thinking about going stand alone but Im use to using my dinosaur moates setup...lol....I like it now cause I now know how to use the dam thing....lol.....Jenna dont you have a big stuff 3?....Dont you use a map sensor instead to tune?...You still have your IAC sensor?..My buddy has that system on his camaro....chinopsu are you using that injector driver from versafueler?
IIRC 83lb'ers are the biggest you can go in a high impedance. If I were you I would ditch the stock ECM and go with the new MS PNP. Although you will have to go with another Trans controller as I dont think the MS will control that. If you plan on making the big power with a 363 the Stock ECU will really limit your tuning capabilities. Just my .02
Im using the versafueler driver
Discussion Starter #13
I could actually use any stand alone as my current computer doesnt control the tranny.....I have a none electronic aode....
Formerly eades5.0
Yes I run a BS3
MAF is gone thank goodness and yes I use a MAP. Still run a IAC also just gm style, along with all my other sensors.
-Chris
1 - 14 of 14 Posts
