Hello,
I am procharging my 96 cobra and am wondering about fuel issues. As you well know the cobra has 24 lbs inj. I also have a walbro 255 in tank feul pump and an 80mm Pro-M MAF. I am assuming I should go with bigger inj. which means i will also need a new calibrated MAF. What size injectors should I go with with 12 psi? Thanks
If you want to be safe and have plenty of room to grow, then you need dislexic injectors ;) In other words you want some 42# injectors and I think you can use the Lightning(newer) MAF. I do believe you have to use the meter as a draw through and NOT a blow through meter.
Hope that helps.
