1 - 11 of 11 Posts
I'm adding a toggle switch to run my fuel pump (magnafuel protuner 625) I want some safety though, in the case of a crash. Is there a way to wire in a factory inertia switch in conjunction with my toggle switch and relay? Or Maybe there is a better way to still have a toggle switch but kill fuel in the event of a crash.
wire it in series with it.
or a relay
pretty simple
that switch takes line voltage
in that diagram
I need to go read more about switches, relays, and automotive wiring more.
all circuits consist of power and a load
that is it
the rest are just switches to control the powering of the load
its all very simple, when you learn the legend and what to look for
The addition of the inertia switch is throwing my limited electrical knowledge into a tailspin, or I'm making it more difficult than it really is.
It’s like a light switch, on or off
Has 2 terminals, you must be making more of it
Do you want to have part of the FP relay control instead?
What is it that is confusing you?
Indy, I sent you an email, that is if your address is the same from a few years ago. Does the inertia switch need to control the pump relay?
the inertia switch can be used to break the control or the line
the switch must be rated to carry the current of the load
Inertia switch should be used to control the fuel pump relay, as that presents only a 1 amp load. Switch can be used to control either the trigger or ground terminal on the relay.
In addition, it is not a bad idea to connect a oil pressure switch that disconnects the fuel pump when there is less than 6 or 10 lbs of engine oil pressure. This would be a redundant set up, in case the inertia switch fails to trip if something bad happens. I bought this Holley switch, but the OEM idiot light signal / circuit could also be utilized.
https://www.summitracing.com/int/parts/hly-12-810
I run both on my street car, and as mentioned, the circuits need to be in series so any one of them will shut off the pump.
1 - 11 of 11 Posts
