Picked up 2 different antennas today and moved them all over the house but could only pick up channel 11 and 13. They are indoor antennas. It's too late now but would an outdoor antenna be able to pick up 2 and 26? In the future I would install one but am pretty discouraged by these. Thanks.
Not in Houston but had the same problem. Bought a $10 digital indoor antenna at Walmart. Cant even get channel 3 which is 5 miles from my house. So I took it back and got a $40 antenna. Can get channel 3 but not much else. Should be able to get 7 local channels but only get 3.
Had to invest in an outside antenna that went on the roof. Get the biggest you can afford.
Thanks. I'm thinking that is the best setup but I just didn't want to install the antenna in my attic and then run lines down to my tv's only to get the same 2 channels.
