1 - 12 of 12 Posts
ok, I have a QA1 K member but I kep the struts and a arms stock. Of course I want to lose more weight now and I want to go to qa1 a arms. I decided I dont want to do coil overs and I want to run my strange 10 way struts I have right now. Are the coil over qa1 a arms diferent from the strut mount a arms from qa1. also, how much weight will I save just doing the a arms and nothing else. And will I need to do a front end alignment when Im done, thanks a lot for the help, you guys rock!!
If the aftermarket A-arms have spring perches then you can do that. If not, then you have to run coilovers. If you don't change the ride height then you don't need to re-align it when you're just changing arms as long as they are the same length as the ones you are replacing.
I'm pretty sure you have to run the coil overs with the tubular a-arms....I don't recall seeing any of them with the spring perches on them.
....you won't regret having the coil over, especially with the strange struts...
I have the qa1 k-member and a-arms with strange struts and coil overs. I was under there yesterday messing with the starter, there is so much more room now instead of tryin to reach around this or that. I used to have to use a 3' ext. on my ratchet and come in from the front, now just give me a socket and a ratchet and i'll brb.
Oh ya....the tubular stuff is great. I've got all the Team Z stuff on my car....I can take the oil pan off the engine with it in the car. That came in real handy to fix a leaky pan gasket.....
I run tubular as well but have coilovers. The UPR kit that I have doesn't have spring perches.
I'd really like to have the factory style back on the front just for more streetable use though.
yes you will need an alignment.
qa1 k member with stock a arms moves the wheels forward, putting on their a arms will move them back to the stock location, so your toe will be all jacked up. i'm sure you'll need to have the caster/camber reset as well.
long story short, yeah you need another alignment.
How are people running struts up front with the coil overs, I dont get it, I thought coil overs delete the front struts. Im confused
1 - 12 of 12 Posts
