1 - 11 of 11 Posts
Car will crank over but won't start with the key, I jumped the posts on the solenoid and it fired right up. I repeated this a few times, it will not fire with the key, what to test first? This a blowthrough carb setup, factory 92 4cyl car.
Park,clutch safety switch
There were 4 wires going to the original auto transmission. Two ran the backup lights, the other two were for the park/switch. I have those two wires ran to a switch/neutral safety switch, when I tested, one wire was hot only in crank, transmission has to be in neutral before the engine will crank.
then its open somewhere to the solenoid
Started on some testing this afternoon, I started looking at the MSD box wiring first, since none of the OEM system has been messed with. Right off the bat I found my 12V trigger wire to be hot only with key on, dead in crank. Tomorrow I'll look for a good 12V in crank and run source.
the distr is fed with both hot in crank and run
use them
you want both in crank and run
use the two on the distributor
I would like to avoid cutting into that harness, since it's so nice n neat. I was hoping to find an old ECM power wire or something, I need to get a hold of a good 4cy car wiring diagram.
take it off the ignition switch
make your own harness
Right on! I was in the process of doing just that, got started, will finish up tomorrow. Thanks.
1 - 11 of 11 Posts
