1 - 15 of 15 Posts
IF turbo seals were bad would you get oil around the mounting flange?? or does it just go right through and out the exhaust?
Both..when mine blew, it spit out the mounting flange and exhaust...just goes everywhere...
Great, Turbo doesn't even have that many miles on it...
What turbo? Is it still under warranty?
Turbonetics 61mm, Warranty? Ha, I bought it like 6 years ago just never got that much run time...
6 years?...yeah that could happen...
I'm going to try an oil restrictor first and if that doesn't do the trick I'll order the rebuild kit. I'll post back results.
Don't waste your time, it's too late.
+1..a restrictor is only going to mask a problem which could turn into a bigger one later on....it's going to leak no matter what at this point...just not as much with a restrictor...
Discussion Starter #12
Discussion Starter #14
So I finally got some time to mess with it and I DON'T think my turbo seals are the problem... I have other issues going on.
I pulled the Turbo off and ran it with out the turbo so see what was going on, and I have raw fuel coming out the exhaust. I backed down the FP all the way (20 psi) and still have raw fuel.
#42's and timing is set to 10, tomorrow I'll check the code...
Discussion Starter #15
Found the problem, #4 injector is stuck open.
1 - 15 of 15 Posts
