Hey all. I have a few plugs that I am not sure where they go to or where the wiring connects. I know they were connected to something before the rebuild but have since forgotten and am having a lighting issue.
The set of 4 wires comes off the headlight harness, but the issue is that when I turn on the headlights the Red/Black wire gets really hot. Also, the courtesy lights on the headlights (side markers - inside and out) don't turn on. The inner ones flash when I hit the hazards, but the outer ones don't. Also, the rear backup lights don't turn on when I am in reverse. AND here is the kicker... The headlights will turn on when both fuses (4 and 5, I believe) are out.
The other pics I just need to know where they connect to.
If you guys can give me specifics as to which wire does what that would be very helpful as this harness is kinda hacked up and it would be easier to fix if I knew the direct line it made.
Thanks for the help in advance.
P.S. I hate wiring
Discussion Starter #2
4 wires from headlight harness
Ttt
Ttt
