Hello all,
Wondered if there are any other 5.0 ice racers out there, and if so, what suspension setups you've had luck with.
The competition in my class is pretty stiff this year, so I'm looking for any advice I can get. :) Thanks!
Mustang setup for studed class only
I've been racing a mustang for a couple years. A lot of it depends on the track as n different types of ice. What I have found that seems to work good is remove the sway bar. You want to have more body roll. This will allow you to do so. 2nd remove your weight. 3rd 5/16'' bolts for studs tack weld the nuts to the bolts n have bolt showing above nuts abou 1/2'' tappered. Hope this helps
