1 - 13 of 13 Posts
Any of you guys running the IAT pre-Meth nozzle and having any issues? I have a 90° rubber boot before the TB and its damn near impossible to have the IAT and the nozzle after the 90° bend before the TB. Its an on3 kit in a foxbody
I don't think you'll have the best results with the IAT sensor before the meth, as the computer will not have any idea what the *actual* air temp is. If you have it tuned that way, it *might* work, but that actual temp will vary as things heat up under the hood. More importantly, with the IAT pre-meth, and the EEC working on the assumption that it's there, what happens if you run out of fluid, or the pump quits, or a line pops off, etc.? BOOM! rattle rattle rattle..... That's what happens! :eeek:
How about a pic or two of your setup? I'm sure someone will have an idea or two.
Andy
Lol. Thats exactly what Im afraid of.
Is there a bung in your intake at the number five runner? Some say it's not the ideal location for the IAT, but that would solve your problem.
Andy
Yeah there is one in the runner and I guess thats where it might have to stay. I know the best spot for it would be the intake piping but it just wont work out that way. I dont have any pics with me but the only way it would work is before the last 90° bend before the TB and that wouldn't be worth a crap
The only pic I have is not a closeup but you can see what I mean basically. Not enough room for the meth nozzle and IAT in that last run before the TB. And how I would get that IAT to stay in that rubber boot is beyond me with it bein 3/8npt
Ok so it wont let me attach a pic...
I run the iat before the nozzle and my iat adder table is disabled. I safely run enough fuel/timing with meth in case the system malfunctions.
I used a step bit to make a small hole in the rubber elbow on the inlet side of my Vortech, and screwed in a 3/8" NPT fitting for my PCV fresh air. This elbow is pretty darned thick, though. I wouldn't do it if it's less than 1/4" wall. (It's also not under pressure.) I drilled and tapped in the aluminum intake elbow for my IAT, but you don't have one of those. ;)
My BBK TB was previously drilled and tapped for a pipe fitting (1/4" or 1/8" - I don't remember which) which I assume was for nitrous or meth. I'll be happy to post up a pic if you think it would be helpful. What size are the threads on your meth nozzle?
Andy
Same here. The tuner had to disable that part of the table b/c IATs would go to 160* and the computer was trying to pull timing even tho the meth was spraying after it. He was tuning it based on the Safeguard knock detector and AF.
ks
There are mixed opinions on injecting meth pre-turbo, and concern with impeller damage if the spray droplets aren't small enough, or if excess fluid is introduced. There can be benefit, though, if done correctly. I've also read that spraying after turbo, but before intercooler can be detrimental, as the fluid can drop out of the airflow as it slows, and gather in the IC. It seemed that the best cooling effects were said to be achieved with a small amount injected pre-turbo with a low-volume high-pressure pump/injector, and more meth injected post-IC. Everything seems to point to it being best before the IAT, though.
I would suggest contacting Michael Plummer here and asking him to give his input into this thread.
Andy
1 - 13 of 13 Posts
