Im looking to see some personal opinions with whatever K-member and coil over kits there are out there. I dont really know much about the AJE kit and doesnt UPR make one too? Griggs? Im open for suggestions:D
-Adam
UGOTBIT said:
I have the AJE setup and have Zero complaints and fit perfectly. I have seen the UPR stuff and it looks pretty good I haven't heard anything about fitment issue though on the UPR .
How much did the AJE kit run you and how much weight did you ultimately save?
Anyone have any info about the UPR setup?
-Adam
I got the D&D K-member, front coil-over, and A-arms for $599 from JD's Performance, but that was at a group purchase rate. I have not installed then yet, but I know many others have this kit and like it.
Another satisfied AJE customer here! I was tight on money so I bought just the K-member for now. Fit fine without any modifications at all. It allows you to use stock A-arms or their Tubular A-arms. Plus you can use your stock suspension stuff until you can afford the whole front end setup(ie-- coil-overs, a-arms, etc).
Dropped about 30lbs off my car with just the addition of the k-member.
