1 - 20 of 33 Posts
Does anyone know how this guy got the hubs for this application? or how he did it? I really love my 93 Cobra wheels and Jeffo said in the past there is no plans of 5-lug, but these fox brakes are scary!! I love my friends cobra brakes, I just don't wanna part with my wheels.
Baer makes pretty much what you are looking for. If I remember correctly it is $1000 plus a $300 core to upgrade to a front setup that use original style spindles, stays 4-lug and upgrades you to either 12" or 13" rotors with PBR calipers. They have many rear setups available also.
Well for the rear he just got some custom lenght 4-lug axles and redrilled the rotors.
No idea how he did the front.
Aren't those Saleens 16" wheels??? How did he clear the 13" brakes??
Thanks I'm gonna take a look at that!
For the rears I figure my 93 cobra discs should be sufficent for now. I don't road race or anything like that yet. Just really tired of less than Ideal brakes in a hi 10 sec street car.
They you definitely would want the baer 4-lug front kit.
It basically is a 4-lug M2300K kit. Same calipers as the CObra...but with better rotors
PS the picture above is for a Honda, but they make a 4-lug Fox Mustang version in 12 or 13" rotors
From what I've read and seen, the Brembo rotors are pretty sufficient rotors for both street and A/X-type racing. Unless Baer is trying to say they're better because they're cross-drilled and slotted, but many people will dispute those features being better than the plain rotors.
Well lets just say better is a relative term. I agree that the 99+ brembos are a sufficient rotor for the 13" setup. Some guys value the bling bling value of crossdrilled rotors. Does nothing for performance but some still might call them "better"
If you look at these images you will see the difference in thickness of the rotors. The BAER Eradispeed rotors that came in my kit have way more material than a Brembo/Ford OE rotor. They also offer a Limited lifetime warranty against warping.
BAER
Brembo
Discussion Starter #14
Anyone have a pic of the modified fox spindles? I'm curious as to what they look like.
I want a set of eradispeeds...too bad it's $500 for a set :(
Those are the 2-peice versions. I meant the 1-peice versions. I forget the exact number but i beleive it was around $500 for all 4 for a Cobra. I could be wrong. It's been a while since i looked
EDit: FOunds the fronts for $250. I can't imagine the rears being more than that
http://shop.store.yahoo.com/hopup1/baresierrose5.html
But yeah, a front and rear set of the 2-peice versions would be awesome. But i have better things to spend $900 on.
There was some interesting discussion about rotor thicknesses vs. air gap over on cc.com a couple years ago - http://www.corner-carvers.com/forums/showthread.php?t=11646&page=1&pp=40 (look towards the end of the 2nd page and into the 3rd page). The thicker rotor faces are good for heat capacity, but it also means the rotors weigh more, and it means the cooling vanes are thinner. So it's a compromise, not sure that thread ever came to a consensus on which is better - more mass or more airflow.
I'm guessing that limited lifetime warranty says they won't help you out if you warp them on track. :)
Let me know if you need the M2300k cobra spindles - I have a set on 88 low mileage control arms gathering dust. Personally, I would ditch the 4 lugs. Future compatibility with rotors and wheels is a real PITA. Get the Baer setup so the wheel offset is reasonable for front and rear wheel rotation. The 2300K kit widens the rear track and makes everything difficult.
1 - 20 of 33 Posts
