1 - 20 of 20 Posts
went to tnt today, ive seen this black early 90s stang there many times, identical to my old car, so i decide to say hey to he guy, turned out he is running a 6.0 motor ls series, i must say it impressed me.,it had a nice ruble to it, ran 11.11 1/4 mile..bone stock lower, and stock heads with springs for cam..had a ots comp cam and the msd box with edelbroke intake and proform carb..the motor was absolutely nasty dirty, straight from the junk yard..if it was anything else he went threw a lot of trouble to make it look that way.. he made 5-6 passes and drove home..
full man 4l60 with a yank pt4000 stall 8.8 4:10's 31 spline 5 lug wolfe thru floor sfc's ground pounder dbl adj uppers upr single adj lowers strange 10way rear shocks stock struts with 12/150 springs ( iirc ) off the shelf comp ls1 cam hand ported heads about equal to 243 castings super vic intake and proform 850 iron block 6.0 with 2007 ls2 crank rods pistons arp rod bolts nothing special about the motor or install and yes it looks like hell under the hood :barf:
lol..did not realize you was on here..i was bragging on ya man..good job..i was truly impressed and i am big ford fan..and a side note, i didt mean anything bad on the dirty motor comment, i was just painting a picture for these guys to see, that it was not some high dollar car but rather a simple build
Sounds like the basic 6.0L swap. I know allot of people hate to admitt it but for the money the motors are hard to beat. What was his MPH?
i dont know..did not look..pretty simple..really the only thing that makes the ls motor so good is the heads flow really good, and it dont hurt the blocks are strong, i have some heads that kick ass, if i was to put them on a 351w ford with a cam and nice intake it would run same or better then a ls motor, but i have about $1500 in my heads, so for the budget a ls motor is very good for using mostly stock parts, i was thinking about putting one in my falcon but it will not fit without putting a mustang 2 front end or cutting the shock towers up..ill use my little 302
There are definitely some other reasons. Try the main caps for example
SBF main caps:
LS main caps:
Discussion Starter #12
SBF main caps:
LS main caps:
looks like a ford fe lower end with sbf head pattern..
Discussion Starter #14
Thats a 69 351W block
i meant the ls block..ford FE motors are sunk in like that..i like my fords..i dont have a issue with ls motor..Gm took the design from a ford..same 4 bolt head pattern..use sbf dizzy in conversion..same intake-exhaust port layout..sunk in main caps..:p
If only Ford would have copied their own design right? lol
Buddy of mine had a FE (390) in a 66 Fairlane. Pulled the intake off once, and because the intake is actually the top part of the heads too, the intake weighed 87 pounds!! lol
The "sunk" design as you call it has nothing to do with the FE or any other motor from that prehistoric era. With the current targets for weight savings, the use of aluminum, the durability and the lower noise, all the manufacturers are designing their motors that way. The imports do the same.
Discussion Starter #17
hey Z284thgen, i seen you at tnt last friday but i did not get to watch you make any passes..how did it do
car is now efi and im tunning on it went 11:23,11:24,11:25 @ 123-125 range
poor DR's are showing cords so its time for new ones 60 fts were off a tenth
1 - 20 of 20 Posts
