Status
Not open for further replies.
Have a pair of the following Hypercoil coil-over helper springs. With spacers.
This "helper" spring will keep tension on your main spring while the car is lifted for service. These helper springs help keep the primary spring from becoming unseated when not under compression.
These short coils have very low spring rates and are coil bound when the suspension is loaded. They will not affect the rate of your chassis springs. It is approximately 1/4 inches long when compressed.
FRONT:
CS100 - 2.5" I.D - 4.000 in free length. 25 lb/in Spring Rate. Steel Spring. Brand New in Box
EIBSPACER250 - 2.5" I.D spring spacer (between coilover spring and helper spring)
$80 shipped (for the set/pair)
REAR:
HELPERSPRG - 2.25" I.D - 4.000 in free length, 25 lb/in Spring Rate
Slight used.
EIBSPACER225 - 2.25" I.D spring spacer (between coilover spring and helper spring)
$60 shipped (for the set/pair)
Status
