Gents
I have an oppertunity to buy a USED HP single kit with a BB 7675 turbo set up for carb. Carb hat is missing... It is missing stuff like couplers and oil lines and other small parts. Comes with both WG and blowoff valve. Does 1400 sound bad? Kit is in good shape.........
Thanks Guys!!!!!!!!!!!!!!
Please call me Mike
I don't think so. That is more than I paid for the used kit I bought, However you are getting a better turbo. FWIW I was not able to use the oil feed or drain with the kit I bought.
If you do buy it or did buy it, get ready to do some cutting. I had to cut out all of the airbox assembly because the turbo sits there. My stock AC system had to be removed. The charcoal canister and smog pump also needed to go. Lastly, the alternator and coolant tube needed to be moved to clear everything.
