Just ordered my on3 kit this afternoon. Doing a whole new setup on the car. It’s still 347 boss block, putting on afr 185’s keeping the f cam. Compression is gunna be around 8.9:1 so I’m planning on spinning it 15-20 lbs of boost. What kind of numbers should I be expecting? Just looking for a fun street car maybe some track here and there
As answered in Windsor Tech........
At 14-15 psi you should be able to double your output.
Theoretically, if you are at 350 horsepower N/A and add 15psi you should be 700 +/- horsepower if at 20psi you should be 810 +/- horsepower.
This all depends on correct fuel, intake temperature, exhaust flow at the downpipe, and other variables though it's pretty easy to get big numbers with boost in a V8.
Ok thanks I would be happy around there
Id say around 650whp through an auto somewhere around 15lbs through an auto and conservative timing if the echaust is pretty free flowing.
Wow and that was with an on3 kit? I’d be very happy around 650
