get under there with a flashlight and look... you might be able to pinpoint it. if not, replace the little rubber pieces on all your injectors... you should be able to pick them up at your local car part store.
do you mean a leak that is spilling feul or a leak that is causing a rich condition?
The o-rings are cheap.....replace them all.
To test if feul is leaking THROUGH the injector, someone told me to put a rubber hose on the end and put 50psi of air through it, subreging the end of the injector in water and see if any bubbles leak through.
I cant smeel major fuel but i havent had tiome to get up close. There is no puddle of fuel. After a few minutes of driving the car sputters and wont barely run and goes full rich. So far i replaced the tfi module cleaned plugs checked the msd and they are fine. This is my next check
did you pull your codes?
Your 02's might be long gone. Sounds like as soon as you switch to closed loop (o2's to figure out pulse width) the mixture gets very rich.........
