I just bought the aluminum taylor battery box...it came with wireing..which I am going to use...so can someone tell me the best way to set everything up...can someone walk me through the steps of installing it...thanks for your help!
I ran the big red wire to the starter solenoid,
the ground wire to the trunk floor inside the spare tire well,
you should drop the gas tank to mount the box directly to the floor using the supplied hardware,
mount it over the back right tire,
lastly, run a ground wire from the engine (where the battery used to attatch) to the chassis in the engine compartment.
However, wiring it this way, you can't install a disconnect switch that kills all power to the car while it's running.
