I would use brake cleaner, and then slab some electrical grease on it.
Just becareful of the pressure of the cleaner. I would think it would be enough to remove the wire completely or loosen it up enough to the point that it may eventually lose contact.
i try a wire brush small one, or sand paper, you just need to remove corrosion, then after doing this i would put some dielectic grease on it
I fiddled with some sand paper, folding it and such to fit it in there and sanded the contacts. Afterwords got some rubbing alchohol on a q-tip and cleaned them well. I then put some dialectic grease on there and connected everything back up. Fan works! I guess it was just the corrosion. Whew...good thing I don't need a new fan, those things are expensive...hehe.
Thanks again :).
glad it worked out for the best, a quick tip is if there is corrosion there you should spend a little time checking all connections on the car, i do this during our long winter here in buffalo :) anyway just a tip to make life easier
