1 - 9 of 9 Posts
Ok, a friend of mine is putting my car back together. I'm wondering if you all could help me figure out what the motor will make and what I can expect for 1/4 mile times from it?
DSS 331 10.5:1 compression
AFR 185 58cc heads
Holley Systemax intake
Comp Cam XE282HR
All the other basics
The car currently has 4.10 gears in it and will be a 5 speed. What do you all think?
Thanks!
Thanks!
Whats it weigh? What Tires?
350-370 rwhp on Dynojet
Thanks!
I think it'll come out around 3200-3300 with myself in it. It'll have 15 inch ET Streets under it.
I would be more than happy in that range to the ground, and just as happy to get high 11s from it.
Id guess 11.50s should be possible, realistically
331, afr 185, Fti cam, holley systemax, 5 spd and 4.10's, 3360lbs and runs 11.7x on 1.5x 60ft times.
Joe
I think that first estimate assumes the car is 2600lbs and will be ran at -500' d/a... think October up in the north east.
I like Joe's car a lot, I think that is a good "real word"... "street/strip" comparison.
Sounds like you are a little lighter, and possibly have a little more compression... so, I'm with tbirdz...11.5's...
UPR coilovers up front with strange 10 ways, baseline relocated upper in the rear, j&m weight jacket style lowers, stock v8 springs and strange 10 ways in the rear, team z anti roll bar. With all these parts the car would not hook until I followed the plotting instructions on the baseline website. Kevin was super helpful and went back and forth with me through emails. I went from a 1.83 to a 1.57 with NO other changes except for plotting the suspension as he suggested.
Joe
1 - 9 of 9 Posts
