1 - 16 of 16 Posts
ive searched but i would like to know how much locked timing i should run on a 95 cobra, on3 MP 70mm, stock everything with 42lbs and meter on 6psi thanks
btw im running 93 octane
Ive been told that since im running such low boost i can set the base timing to 10 degress and run stock. But i think id like to try 8 degrees base with the spout in. Anyone have any objections
U might want to be careful doing that . Even @ 6 lbs it's gonna make a lot of power. Won't take much to rattle that motor and burn it up. If your gonna run with no tune lock out the timing and keep a close eye on the afr.
What should it be putting out on a 95 cobra all stock besides 70mm throttle body 42lb squirters and the 70 mm turbo at say 6 psi and 10
Well i set the base timing at 6 and put the spout back in. I hqve to wait til tom to drive it because of a storm. Im going to listen for pinging and slowly increase it to 8* Ill be getting it tuned in a week or so
8 should be fine thats 23* total timing. i was pulling 1* for each lb of boost my total timing was 15* @ 15PSI. so that would be 24* @6PSI
<newb.
I've searched but can't find what I'm looking for. When u say you pull 1* is it assumed that everyone starts at 10. Also how do you do thar math to come up with your statement above. I'll keep looking also.
<newb.
the op is using the dizzy to pull timing. base is 10* and ecu adds 15* at wot
so if he sets base at 8* wot timing would be 23*.
i am using an amderson pms i can pull timing out when the car builds boost. i have base set at 10* and add 20* at wot then pull 1* for each lb so at wot and 6psi im running 24* and at 15psi im at 15*
Generally the pulling timing per pound of boost if from where you motor makes best power N/A for example my setup after alot tinkering and tuning made best power at 36* total, i pull 1.5 per psi so at 6 psi came up with 27* total. Ran it like that for a long time. I upped the boost to 12 psi and now i run 15*, pulled a little more to be safe as i ran into detonation at 18* on 91 pump gas.
My setup, completely stock running 8lbs 17* total made 370hp/450tq
1 - 16 of 16 Posts
