I have a set of Bilstein struts and shocks from a low mileage 03 Cobra that I plan on selling. Can anyone tell me what they're worth?
The struts have similar valving to the HD and will work on 87-04 Mustangs. The shocks use valving designed for the IRS and are not appropriate for a stick axle. Therefore, unless you find someone needing dampers for an IRS equiped car, the struts are the only valuable components. MM sells new HDs struts for $219 each (DOTD, just under $200).
