1 - 12 of 12 Posts
Just wondering how much power a 3.5 inch down pipe will support I have a y2k 80mm turbo just wondering if I will need a bigger down pipe or will 3.5 be sufficient thx for any help
I've seen a 3" support over 850Rw...so like Nipples said...it alll depends on your setup
Really depends on cubic inch, turbine, housing, basically everything that contributes to backpressure. A Mod Motor with small cubes will likely support more with a 3.5" DP where a big inch pushrod stroker will support less (in general).
yes, def depends... how big is the turbine wheel inside that turbo?
A dp larger than the wheel wont help all that much to my understanding... reason Hellion uses a 3" dp on their 76mm kits. That T76 only has a 67mm exhaust wheel so a larger dp than 3" wont really help with only a 2.6" wheel.
But on something like a Comp 8488 it would benefit seeing that turbo uses an 88mm (3.5") turbine wheel... so it would choke on a 3" dp.
Jersey True Street Guy
I made 930rwhp with a 3.5 inch and showed more power at track
1 - 12 of 12 Posts
