Just purchased a 2000 GT, noticed clutch pedal is 1 1/2" or so longer (further from the floor boards) than the brake pedal, is this normal????
Thanx,
olbob
Mine did that after the TSB for a vibrating clutch was done. I has settled a little bit, but it was 1-1/2 above the other pedals at first.
Alot of the 2000's had a plant defect that made the clutch pedal vibrate at about 3000 rpm. It is not a recall, but they will fix it if you complain. They replaced my clutch, flywheel, pressure plate,, and throwout bearing. It has been very smooth since.
