1 - 20 of 85 Posts
I just purchased a 86 GT convertible. Bone stock execpt K&N filter and CD player, if you wanna call that a mod. 135k on the odometer, 5 speed, 10 holes, etc., etc., I got it on sunday and ran it down the track on friday. I didn't even check the timing. I ran a best 15.62 at 88.7 mph; 60ft was 2.46 (it was a one wheel wonder, running on 215's). For those of you who were able to run your fox body bone stock how did your numbers compare.
Update 11-24-08:
Well I have replaced the wornout diff. now both drive wheels spin. While I was in there I also installed 3.55's installed new strange adjustables, eibach prokit, chrome 17inch SC with MT Drag radials in the back and finally bumped the timing from 9deg up to 15deg. This gave me new results of 14.95 @ 91.6mph; 60ft came down to 2.13. I am disappointed with the 60ft but I guess I just need more practice.
I ran my old 87gt bone stock to the mufflers, had 180k miles on the motor, it went 14.9. This was also my first time racing a 5 speed car at the track.
1991 Mustang GT with a 5 speed and 2.73 gears and about 200,000 hard miles on the motor. First time ever at the track went a blazing 15.3 at 91. Learned that an unprepped track actually has less traction than the street. And to think 4 years later the car runs 5 seconds quicker and 40 mph faster.
99% stock coupe with bumped timing, o/r h-pipe and smog delete...13.9 @ ~98mph (with stock 2.73 gears too!) :)
my last gt with 74,000 miles 2.73s bone stock with smog and everythinig went 14.2 @ 96 mph then put in 4.10s and went 13.6 @ 104
My 93 GT only had 54k miles when i got it. First time at the track with only a K&N, Bumped timing, Smog delete, with off road h-pipe but stock catback with 4.10's I went 13.5 @ 105 while still running BFG traction t/a's on stock pony's
I can believe the 1/4 time....but those trap speeds are not going to happen without other mods and/or weight removal, sorry.
91 notch stock ran 13.60 @ 104
Again, you guys need to mention any and all mods...because I garuntee you were not stock running those times.
89 notch bone stock with 3.08 gears went 14.00 @ 99 in 52 degree weather, 88 notch with bbk shorties, bbk off road & flowmaster catback went 14.1 @ 98, 85 degree weather with the rear brakes dragging.
Bone stock AOD w/ 2:73's went 15.2 @92. First time ever down the track
With full exhaust, pullies, bumped timing, and 4:10's I got it to a best of 14.09 @ 98.
I agree with Millhouse. You guys running 104-105 bone stock are dreaming.
88 speed density gt hb with 14 degrees bumped timing,pulleys,air filter AOD w/ 3.27 gears 14.50's all day long
95 gt 5spd 2.73 gear with 12 degrees bumped timing,air filter 14.30's to .50's at 95mph
pulled belt ran best 14.00 at 99 mph
1 - 20 of 85 Posts
