boom and the end of the track!! engine run crappy and surging alot, compression check not too bad, but i need to learn how to do the leak down test . with valve covers off and rotating by hand i can hear pressure leaking into the bottem end , air noise is coming up through the chain cover. please help me learn this leak down test i believe i my have a broken ring land. this is a 2 valve motor but the test should be the same. leave phone # if you want and i will call you or leave response on this forem
Well 1st you need to have the leak down test gauge or kit, Then you set each cylinder to where the intake and exhuast valves are closed, next connect a compressor hose and pump the engine full of air. The leak down test guage set has a gauge that will tell you how much air you have bleeding down. Sorry these directions arent exact but these steps pretty much sum up what must be done.
